- Jan 21, 2000
Could you tell me about your experience with the stellite blade forged by Steve Schwarzer? His experience as reported in the January 1999 BLADE indicated the blade during forging couldn't be straightened over an anvil with a hammer, and even resisted a 35-ton hydraulic press.
My Q's:
1. Did you find the forged material different from 6BH or 6K when you were grinding, finishing and sharpening it?
2. What performance differences would you expect, given your experience with the forged material, in the areas of toughness and edge holding?
3. Given the elemental changes in the alloy makeup from forging, as indicated by the lab reports on the forged blade, what predictions could you make about how the alloy might perform in a blade, as compared with factory products?
ON ANOTHER TANGENT--
With your extensive experience with 6K, 6BH and many of the new hi-tech steels, all other things being equal, which material would you choose if a high priority was to defeat one of the following failures:
A. Blade breakage due to flex
B. Edge chipping
C. Edge cracking due to flex
D. Edge rolling
E. Which material will support the thinnest distal taper and thinnest edge at the secondary bevel, if cutting in soft material such as meat and hide is the application?
Thank you, Kit--Will
[This message has been edited by WILL YORK (edited 01-27-2000).]
My Q's:
B. Edge chipping
D. Edge rolling
