- Jun 29, 2001
I got some new coal from a different supplier. cleaned out the forge and tried to light it.
back ground, my forge is made from a brake drum, nesting in a 35gal. steel barrel. the grate is a piece of 3/8 steel. air is inlet through a 2 inch pipe welded to the grate. It also passes through a hole in the side of the barrel.
here's where it gets interesting. for some reason I could not get the coal to light.
anyway I resorted to a small paper cup of gasoline poured at arms length(while held is my longest tongs)over the coals.
through in a matchfrom about 4 feet back and turn on the blower. i got realy nice flames for a moment, and then the unexpected happened. I must have got gas fumes in the bottom because it went poof!! and a long toung of flame shot out of the hole in the barrel around the air inlet pipe. My son thought it was cool. I wasn't so happy.
any way we did finaly get it lit,and it burned realy well, and Bruce Your instructions work
I'm still on the hard end of the learning curve, but that's what I expected
