forgeing the bevel for your edge
i have just started forgeing the bevel for the knife's edged im useing a 6lb hand held sledge and 3lb driving sledge is there anther type hammer which would make this operation easier there any trick to making the edge even other than eyeballing the blade frequently.
Thanks Russ
I use a three pound hammer. The heavier the hammer the more metal is moved, However you don't want a hammer so heavy you loose control of it. Five accurate little blows are much better than an out of place heavy blow. Know the forging temperature range of the steel you are using. Don't hit the steel when it too hot. Also Don't hit it when too cold. Work both sides of blade equally with your hammer. Keep blade trued up as you work. There are several good books on forging blades. Hope this helps you.
BlacksmithRick@aol.com
I have a 21/2lb that I work the bevels down with, then I switch to a modified ball peen, the face is lightly crowned and oblong, the long side of the oblong is used for the bevels it pushes the metal the length of the blade.
Keep your blows even side to side.
The metal in the top of the blade under the hammer will move more than the metal against the anvil. Forge on.
Sola Fide
Russ, when forging the bevel on the blade, (I'll say it again) make sure you work both sides evenly. It's the most important thing to remember. In fact, I learned a trick at the Hammer-In at Washington from Mr. Keeslar. When just starting out, count the number of blows and try to measure the energy of each blow. Start at the ricasso and work toward the tip of the blade. Count your blows, flip the blade and deliver the same number of blows. Use, light rapid blows with a medium sized hammer. A rounded face will help you more than a flat one. Less grinding later. Also, don't forget to bend a radius in the blade from ricasso to tip. You want the inside of the bend to be the edge side. The blade will straighten out as you forge the bevel on. You just have to guess how much bend, depending on thickness and width of your steel.
When you get close to shape and thckness, switch to a lighter hammer that is polished and tap, tap, tap your way to a nice semi-finished blade surface. My tap, tap, tap hammer is a 1.5 lb. straight peen. I modified it to do the finish work. Also, a shorter handle will help you to develop more accurate blows in my experience.
I've seen your hammers, old buddy. You need to invest in some variety. I'll bet I've got 20 hammers in my shop. I don't use them all, but occasionally, I'll find that I need something a little different and find that I already have what I need in my collection. I buy them at a local flea market. Get them for pennies on the dollar and clean them up as I find a need for them. Email me and maybe I can set you up with a few. Whatever you do, don't waste your money on the cheap hardware store variety. They just don't stand up to the kind of punishment you're going to give them. My email address is mburnett@cswnet.com
thank for the knowledge and advice went scrounging through my tool found a 32oz ballpeen which i sanded down and polished the face it seemed to work fine used it on the knife for a friend grandfather if everything gose as planned this will be my second sell.
Thanks Russ
