- Jun 11, 2006
I have been silently working on the press in the background. I have taken loads of pictures and plan on updating the build thread soon. The press is not officially done as I still need to mount the vfd and replace the temp wiring and tie that all up. But last night I got a set of dies made and wanted to test the press out. The night befor I tested it on a 52100 roller bearing to see how well it squashed it.
I had this Damascus billet left over from befor I moved to this new house. It was giving me problems with my mini press because of its size. I had cut some off the end and forged it out but the main billet has sat for over a year in a bucket. I figured why not try to forge it out and see how long it takes. Here is the billet befor heating it up.
I heated it up and let it soak then I brushed all the old gunk off. I added more flux and reheated and brushed. There where a few areas on the sides that had not closed yet because my mini press just did not have the tonnage. I fired up the press and gave it a squeeze.
I was absolutely blown away by the speed at which it moved the steel. I know I knew that the press is only one speed but untell you experience it your self it’s hard to describe. And I’m running at around 20 tons at 1.5-1.7 in/sec. And I’m convinced now that speed is more important then tons. If you can move the steel fast enough it puts up hardly any resistance. If you let it cool down then you defently need more tons. But my thought is by keeping it at the upper end of temps your working much faster becaus the reheat time is much slower and moving that steel is quite quick.
So learned the foot control needs to be babied. I only have an upper limit switch right now but will be adding a lower limit switch. These can be set to control up and down stroke. If you space out for a fraction of a second you have squished the steel to far. So I do need a lower switch. But all that being said and my just trying to kiss the billet I was able to go from that big billet to this bar in about 20min. I feal like I could have done it much faster with the lower switch and if I was not fighting my propane bottle. It was running out and I was trying to get every last drop out of it. This bar is 2ft long and about 1” wide and close to 1/2” thick.
I’m super glad I did the research I did and went with the smaller diameter hoses. This press came out so much better then I could have hoped for.
