Foster Fears Survival Knife
OK, let's try this again, and hopefully not lose it to the ether...
Funny how after a while here on BladeForums, when someone says "survival knife" you start thinking of a Busse SHBM, or CS Trailmaster, or SWKW Ratweiler... yet somehow, so many people have managed to survive all these millennia with much smaller, more handy, knives.
The Foster Fears Survival Knife definitely falls into the latter category.
Like Tom, I sorta expected a big ol' hunk o' steel in the USPS box; the Fears ain't all that big, but as soon as I drew it from the sheath, it was clear it was a tough, no-nonsense knife. The thick, saber-ground blade may be only 4-1/2" long, but damn solid; likewise, the textured international orange G-10 scales are both functional and solid as a rock. Rather than decorative pins, the scales are held on with oversize hex-head Chicago-style screws, in case you need to remove the scales for cleaning. The tang is full profile, un-tapered and has no lightening holes; compared to the D. Winston passaround folder I just handled, this thing feels like a crowbar!
However, in its belt sheath, it's really not very heavy at all. Just sturdy. And functional: I know Daniel Dorn took it to N'awlins for work, and I have no idea what horrors TOB put it through, but by the time I got it, this knife was well-used! A little scrubbing in the kitchen sink, a little touch-up on the Sharpmaker, and the Fears Survival Knife was ready to roll.
I cut up some cardboard with it, whittled some fallen branches, and used it a bit in the kitchen, but sadly, that's all the testing I could manage last week. Even in that limited use, though, the Fears showed a lot of promise.
On cardboard, it cut fairly well for a thick, saber-ground blade; although the blade is "only" 440C, it held an edge quite well, better than a lot of stainless knives I've used. Ditto on wood; it cut well, and was easy to control. In the kitchen, it didn't slice as well as my wafer-thin Forschner santoku, but proved a sturdy yet nimble cutter on materials from carrots to a whole chicken.
The handle looks small at first glance, but is thick, well-rounded, and surprisingly comfortable in extended use. The highly-arched spine of the handle may not win any awards for aesthetics, but is supremely functional — it drops the blade down to create a substantial lower guard, yet keeps the knuckles up high off the edge, which is a godsend for food prep. The rear of the spine is aggressively serrated for traction, and the sides of the G-10 scales are well-textured for a secure grip.
The blade is well ground, but has a bead-blast finish; this isn't a mall-ninja tactical blade, and in such a corrosion-resistant steel as 440C, I would prefer a satin finish. In a survival situation, wouldn't a shiny surface be a "good thing"?
The only other thing I can complain about is the sheath. It's nylon with a thick ABS insert, but the nylon isn't very heavy, has a too-big and chintzy plastic D-ring at the bottom, and is badly glued at the throat of the insert; also, the insert itself is a bit loose, so the blade rattles in it. As mentioned in the passaround thread, newer Fears knives will have a better Kydex sheath, which sounds like a great improvement!
I would've looooved to try batonning some wood with the Fears, but since it was a passaround, I didn't. I have no doubt, though, that it'd take quite a beating, and come back for more. This is a knife that is designed, more than anything, to be used.
If you're looking for a no-nonsense outdoor knife that's highly visible, tough as nails, and comfortable to use, you could do a damn sight worse than the Foster Fears Survival knife. It might not be as elegant as a Loveless custom or as impressive as a Busse, but you also won't cry when it gets it's first scratch, either... in fact, I'm betting you'll want to get a lot more on it. It's that kinda knife.
Works fine now!
(Check the timestamp, I was getting a wee bit groggy when I posted it. :yawn: )
I was in a pass-a-round for one of these awhile back, REALLY liked the knife, but he sheath that came with it at the time was horrible.
They have recently announced that the new sheaths will be from onscene tactical.
Thanks for the review:thumbup: . Its nice to see someone testing a smaller survival knife thats really not what you'd think of. I look forward to hearing more about this knife.
How thick is the blade? That half-height saber grind kind of bothers me--if the knife is very thick that edge geometry won't let it cut very well, and if it's too thin (below about 5/32") I'd worry about its strength, especially with the steel run that soft.
Ya know, I meant to mike the blade, but kept forgetting. It looked like between a tenth and an eighth (0.100"-0.125"). It seems pretty chunky, but cut pretty dang well.
Thanks for the excellent review!
I would have preferred a satin finish also, although I suppose that the matt finish is appropriate on the subdued black and canvas micarta handled military versions.
As with most full tang knives, I would have also liked some cutouts in the tang for a little lighter in the hand balance….just a personal preference.
The curved handle shape is very comfortable and secure – much better than a straight handle in my opinion.
With the new On Scene sheath the Fears Survival Knife should be good to go right out of the box for anyone looking for a practical, no-nonsense knife that is sturdy enough to depend on for survival but not too big and heavy to have with you when you actually need a survival knife - definitely the kind of knife that begs to be carried and used!
- Frank
PS: The blade spine thickness is about .145”
PPS: Here’s a Survival Knife article from SCI’s Hunt Forever Magazine by J. Wayne Fears:
http://www.scifirstforhunters.org/static/index.cfm?contentID=443
Well, I'll be dipped. Tiem to send my eyeballs in for calibration, I guess.
That's a pretty thick stock for a blade of that size, doncha think? No wonder it feels so sturdy.
A little on the thick side for a hunting knife maybe, but definitely not pry bar thick. It cuts well because the edge is ground fairly thin.
- Frank
Considering the length, thickness and sabre ground profile, it is more of a pry bar than a 1/4" bowie with a 10" blade. From the description of the knife laterial strength is one of the designs, prying is mentioned specifically on several occasions.
It would be interesting to compare something like this to one of the more cutting based survivial knives like the Mora 2000 and see which one was more efficient (time/effort) over a broad base of activities in various enviroments for different users.
-Cliff
Hey Gryffin...
Edited...
sorry I didn't realize that this was a pass around..
I'd like to send a sheath into the pass around if there is still time...
ttyle
Eric...
No worries Normark...
The next person will recieve the sheath tomorrow. I think everyone will be very pleased with it.
Hey Matt...
Excellent..
Thanks for sending that out..
I hope everyone likes it...
Got a nice stack of Fears sheath blanks piling up here..:)
ttyle
Eric...
