 - Jun 26, 2007
Two days ago I was driving here around my Panda 4x4
and I realized that I had two neck knives in my bag, the Fox Compso and the Cold Steel Super Edge
They are two very compact and light knives, and they were made to carry them around the neck, or in a pocket, in a bag or at the rucksack shoulder strap
The Fox Compso has a total lenght of 145 mm, the blade is 70mm lenght; the Cold Steel SE is even smaller, the total length is 105mm, the blades length is 50mm
Handling the Fox Compso
Handling the Cold Steel SE
Fox Compso blade, is a modified spear-point, thickness is 3mm, scandi high-grind and long false edge
Cold Steel SE blade, is a pure spear-point, full-flat grind, thickness is 1,5mm, and is serrated
Carving wood, the Fox Compso works fairly well, the handle is long enough to allow a good control and pressure
Some feathers, its easy to obtain them
Carving wood with the Cold Steel SE, the handle is a bit too small to work properly
Some feathers, its easy to obtain them thanks to the serrated blade too
Conclusions:
both the Fox Compso and the Cold Steel Super Edge they are very practical knives, and they both are great for EDC, being small, compact, light, easy to carry and very efficient to cut. The Fox Compso imho is good too for outdoor activities, the handle is long enough to carve wood and the holes on the handle and the blade allow, in case, to fix it to a wooden handle (see here , at 4:51 Fox Compso 31dic2012 - YouTube ). The Cold Steel Super Edge is very, very light and small, its great to be attached at your key-ring if you want a capable fixed blade in every moment, or for an emergency kit.
Ciao,
Alfredo
Conclusions:
Ciao,
Alfredo
