This one specifically: ... The blade is a shape that makes it kind of useless for anything but stabbing and throwing.
But you wouldn't buy that blade shape expecting to use it as a utility knife.The same could be said for all the knives in the Exagon line. There is no evidence of any of them being made of a "throwing knife" steel. "Throwing" in this case is just a sales hook.
You'd rather use a nearly straight blade instead of one with belly?
Neither of those are the same as the Exagon throwing model though... It's a slightly rounded triangular blade. Almost like a dagger.Ask a wharncliffe or sheepsfoot.
Yeah, I've seen how cheap ones shatter or snap. I still don't see why you'd buy that blade shape when you have other, more useful ones to choose from.I think I would be more inclined to use that knife in a non-throwing role. However, I don't know what the hardness (Rockwell C scale) is, but I want to think that knives made for throwing rank several points below a knife meant to hold a good cutting edge. In other words throwing knives are "softer" so that they will not break as easy when hitting a solid object such as a rock, not that the rock is the intended target.
Boker Magnum makes a set of throwing knives, as does Browning, Cold Steel, Condor, and United Cutlery makes some Gil Hibbern designed throwers. Any of these can be had for under $50.
