- Jun 26, 2007
There are good sons and bad sons. The Fox Parang XL was a bad son. At the beginning, because of a worst grind on several knives, several Parang XL were fragile, and several customers were disappointed. More, the handles scales were uncomfortable for few customers. You know, the beginning of a product is like the first look of a girl, could be a sentence of death in some cases
For example, take a look at the reviews on Heinnie Heynes http://www.heinnie.com/Parang-XL/p-0-0-5658/ who would buy this knife anymore, for the love of God?
Well, that said, I know the Parang XL was a good project at the time and is a good machete now: Fox changed the worst grind immediately after the bad experience
and now the Parang XL has a new handle too (below on the pic)
So lets get a try, the weather is perfect
The Fox Parang XL handled
First, cutting down a tree (diameter 9 cm note: that tree was fated to be downed)
Now, cutting a segment f 1 meter, and I use the Parang XL at two hands, to eliminate the bark
The cutting efficiency is quite great, and the new handle is comfortable. Please note that the thickness of the blade is just 3 mm, so you need to use the Parang XL as a cutting tool not as a sharpened bar, I mean is not a Busse or similar.
Now, using the spine of the blade to scrap the wood, to obtain shavings
Finally, clumping the knife whit my foot, and using the firesteel on the blades spine , to ignite shavings
Here a footage of the trials
http://youtu.be/toxuAtSaqpU
The Parang XL at the belt
Conclusions: the Parang XL is now a good machete. I wanted for a big knife to be used on the temperate forest too, but not a 1 kg of steel to be carried, and I guess the goal is now achieved. I repeat this is not a sharpened prybar, I mean if you are looking to a knife to be used without care on the woods, this is not. You need to use the Parang XL remembering is a big knife with a thin blade. More, its obviously not an all-around knife, you need to carry also a multitool or a small knife for small jobs in the woods. If you contrarily are looking for a great cutter, to clean a track or for the tasks as I showed above, the Parang XL might be the knife for you.
Ciao,
Alfredo
Ciao,
Alfredo
