Hi all,
So been looking at these foxy folly's coming up and I love the look! I'm just wondering what the steep forward sweep is designed for? Is it designed for chopping better as more weight on the front? Sorry if I haven't worded it well!
Ah I see, well it is a beauty but I'm sort of after another workhorse, probably the m-43 or the BAS![]()
I also have an 18" CAKI sold my hatchet after buying it, it's the most capable knife I think I have ever owned! What's other people's opinions on the western handle vs the traditional?
I have both kinds of handle and I like both kinds. However, I prefer the traditional handle because the ring locks the hand onto the handle.
It takes a little getting used to, and most people expect the ring to cut into the hand. However, a small adjustment in the grip pretty much eliminates that problem. The ring goes between two fingers, of course, but the trick is to slightly cup the palm of your hand so that the other side of the ring doesn't cut into it. It means you're not squeezing the handle in a death grip, which many westerners tend to do.
Following are pictures of an extreme example.
[View attachment 676174 View attachment 676177 View attachment 676176
It's a steel-handled ceremonial khukuri, 25" OAL and 42 oz, probably from the WWII period, though it might be a lot older.
As you can see from the photos, the ring is about as nasty as they come. I couldn't hold the knife at first, but I experimented with various grips and after a short time I was able to hold and swing it without the ring cutting into my palm. If you can do it with this ring, you can much more easily hold a normal traditional khukuri with no problem.
