Foxy Folly
OK, I've admitted this before and I'll admit it again: the great fuss about new models and slight changes is silly. Physics are physics, Mares eat oats and Doe's eat Oats, and little Lambs eat Ivy. You can't get there from here; you can't reinvent the wheel.
But the darn thing is so neat. And it does Ring. When old hands like Yvsa get excited, you'd think I'd sit up and pay attention. I'll try it out, I'll pound some wood, we'll do a little stepping out.
I can tell you already it has magic in it. You've got your 24 oz- a weight reached by careful analysis of what weight was best for cutting in a hand held blade. 24 is at the bottom of the true choppers. I prefer 28 oz. Then there's the fullers- instead of the metal in the blade and the normal HI heavy duty thickness of 5/16 or 7/16's or even a half inch, the Foxy Folly is just a fat 1/4 inch in spine width. Those fullers add back the strength more metal would have normally provided, and gave you khuk nuts the beauty you all craved. It's a deep blade. I've always wondered about this shape type: does this impart any feature to the actual chopping that just a iron weight welded to the back of a slender edge would provide? I don't know, but once again it just looks good.
And the length- 17.5", is in the prime zone of leverage and reach for serious chopping AND what is still practical to carry in the field all day. The tang is normal khuk and I would not have wanted a chiruwa style because the extra weight would change the balance this one has. ANd no mistake, it has a special balance all it's own.
Will it outchop another 24 ouncer? I've got a BAS to put it against. Will it compare in chopping to a 18" AK? Don't know- if it did you'd have your cake and eat it too.
But it's a keeper. I can already see how much easier it will be to take along than even a slightly longer, heavier model.
Congratulations, all of you with the vision and little kid hopefulness to have signed up for the new improved Foxy Folly. You will not be disapointed in your perfect specimens as they arrive from Nepal.
edit; one more thing; Once upon a time I reviewed here another distributor's khukuri. It was about a 1/4" thick at the spine. Proponents of this blade said it was harder to make a thin blade than a thick one- like the thick HI blades.
I'd asked several Smiths about this at the time and the general answer was it was no harder to make a thinner blade than a thick one. I observed at the time this Other Blade had a lot more wavers and hammer depressions in it that does a typical HI blade. This was attributed by some to the theory- thin blades harder to make.
This Foxy Folly has two distinctly well formed fullers in it. They are magnificent, and all surface on the blade is wonderfully well formed and smooth, almost as if poured from the Smith's hands.
HI Kamis make damn good blades thick thin and inbetween.
munk
My favorite khuk is my 16" GK Bonecutter. The way the weight is distributed in that khuk is what makes it my favorite. I'm not sure how to describe it but the bend is real near the handle, and then it comes out fairly straight which leaves a long area to make contact with the wood.
Looking at the FF it is like the BC as far as the way that bend is near the handle. That's what makes me want one. The curve is not way out there. :thumbup:
munk said:
That's a very astute point about the curve, Hollow.
munk
Thanks. In one way a curve way out the blade is good cause you can kind of lean over a log and cut under it, but in another way it kind of gives you less of an area for the wood to make contact with in regular cutting. I can't wait to lay my hands on one of the FF's. :thumbup:
I did some initial testing of the FF today with a 6" diameter mostly dry pine log. I also cut the log with a 15.5" 23 oz BAS. The truth is the FF did not defeat the laws of physics. It cut a similar amount to the BAS. It may have cut a little better, and the swings may actually be easier because of the remarkable balance. I'll be doing much more extensive testing later.
If the FF doesn't cut any better than say a WWll 16.5" of roughly the same weight, (this being close to the FF specs, though of course both a light and normal weighted 18" AK would also be very instructive.) it may come into it's own as simply easier to use with repetitive, multiple hits. You won't get as tired and be able to cut more and quickly too. The loss of the forward weight momentum is very noticable when using the FF as compared to standard HI khuks. Doesn't hit with the same authority.
munk
Good stuff, Munk. I'm glad that you like it.
If you're going to do a chop-off, make sure that the job lasts a while. The FF's balance really shines when you're still going after something heavier (or biased more toward the tip) would've already tired you out.
That's what I expect now; that the FF will be a delight to carry and use, with less fatigue. And it sings a little song, too.
munk
If anybody has one of the spec Foxies, your know the 17 inch ones, and you decide you'd like the 21" fighter version, send me an email.
(even if yours is a blem)
** done deal!
