- Oct 25, 2004
Have you ever had one of those pieces of furniture sitting around that was technically nonfunctional and really should have been discarded long ago, but you just never got around to it?
I had a rattan chair. The swivel had broken on it years ago and it was nearly impossible to sit on. I'd circumvented the problem by placing the back against a wall to support it. While no longer an acceptable chair, it soldiered on for some time as a place to put things. It probably would've remained there for years to come.
Several of us were admiring the Foxy Folly's balance and suddenly, without a word, all eyes fell on the chair. After a moment of silence, someone remarked that it was time for the chair to go. Then came the mention of the Foxy Folly. Before anyone knew what was really going on, the chair was on the chopping block.
Things got a little out of hand but a test is a test. I was curious, not only about the Folly's heat treat and its ability to hold an edge, but also how such a thin blade would fare against some enthusiastic mishandling.
The aftermath, with my assistants, Ben and Jon:
The splitting maul was necessary to remove the base of the chair. I didn't want to chop up any metal bits with the Folly...yet.
Yes, I did get a few licks in there, but Ben and Jon did most of the work. If they couldn't break it, I doubt that I will.
The victorious Folly:
Despite some bad contacts the edge held up fine. It picked up some toothiness that could be felt with the thumbnail but couldn't be seen. It aquired a nick that's probably too small to photograph; it can't be seen easily without very good light. It nearly disappeared (and the toothiness was gone) after a stropping. Part of this may be because I thinned the edge a bit on the belt sander. (Old habits die hard.) It's probably too sharp as it is. I may increase the angle a bit the next time it's on the belts.
So far, so good. The heat treat appears solid. Even the tip held up fine. My concerns are largely gone. I intend to perform some serious woodworking later this week. Green wood ought to be a piece of cake. I'm very curious to see how it tolerates seasoned pine.
If this one is any indication, these are really going to be amazing. Everyone's first comment seems to be disbelief at its weight and its fabulous balance.
