Could be for a few reasons, some of which are cause for concern, others of which aren't.
Starting with the "not a cause for concern" reasons, sometimes the surfaces of the blade tang and lockbar will simply be so smooth or well-matched that, although the lockup/contact is perfectly secure, they disengage with no "stickiness" or "click" at all. A couple of my ZT titanium framelocks have been like this right out of the box, and many others have been like this after they've broken in a bit and/or after I've applied Sharpie to the blade tang.
Another reason, which of course is a cause for concern, would be that there's a problem with the engagement between the blade tang and lock face. At an extreme, it could be that they aren't touching at all, but more likely (that is, likely relative to the "not touching at all" possibility) would be that they're engaging in such a way as to be unstable or prone to slippage/disengagement. A couple ways to test if what you're describing with your BM 755 falls into the "cause for concern" category would be to check for vertical blade play and/or to see if the lock bar slips off the blade tang when you apply firm, consistent pressure to the spine of the blade. (Obviously, with this latter option, make sure to do it in such a way that if the lock does slip off and the blade starts to close, you don't cut yourself. Also, so there's no confusion, I'm not advocating anything like the utterly stupid and useless spinewhack "test" -- all you're doing here is putting your fingers against the spine of the blade and applying pressure to see if the lock slips.)
