It was the Kizer T1 Titanium. I figured it out that the only way to open it, if I rest my fingers on the clip. The problem is that there is no room for four fingers on the clip. Only for three fingers. So 8 out of 10 tries I can open it, but after a week of trying this, I just fed up with this.Which make and model knife are you learning on; some are more problematic than others. I assume this is a framelock flipper you’re working with?
One common method is to place your lock side fingers on the clip rather than the lock bar, but that can vary model by model.
Me either, but I usually use two handsI never had a problem opening any of the framelocks I own.
Try a drop of lube on each side of the pivot.It was the Kizer T1 Titanium. I figured it out that the only way to open it, if I rest my fingers on the clip. The problem is that there is no room for four fingers on the clip. Only for three fingers. So 8 out of 10 tries I can open it, but after a week of trying this, I just fed up with this.
This. My Spartan Harsey refused to open for me, but I determined that what K.O.D. mentioned above was the issue. I adjusted my grip and it’s great now!Most people who have issues with opening framelocks are putting undue pressure on the lockbar,causing the detent ball to hold the blade in place.
This…and it might help to get a little oil into the detent ball hole and path. It can be a little tricky to get to that hole without disassembly, but if you get the oil close it’ll work it’s way in.Try a drop of lube on each side of the pivot.
Try opening it with your left hand - if that works easily, you're still pressing on the lockbar when using your right. If that's the case, try middle finger flicking it...this can be a little weird at first; but it's fairly easy to get used to, and it works (as long as you have good enough access to the thumbstuds).
If none of those things work, get rid of it - there are too many knives available to continue struggling with one that doesn't want to open.
