Thanks kevin and mete. That was one of the simplest technical explanations I've see.
I've used the Toy box example to explain it to those who can't wrap their heads around crystal shapes
this is an analogy, and not 100% exact.
Remember when you got a box of
BLOCKS and
BALLS to play with, they came neatly arranged in the
BOX in nice rows, 50 blocks and 50 balls, with a plastic cover on the box (This play set was called the eutectic box of iron and carbon). The box is the steel, the blocks are the iron , the balls are the carbon. After playing with the blocks and balls (forging),and thus destroying the plastic cover, you try to put them back into the box.....they won't fit any more. They are all jumbled up, and take up too much space.So Daddy Kevin shows you a neat trick..... the blocks are hollow, and that there is a secret door on each block that opens up and you can stick a ball in it. The magic word to open the block up is
Ac1, (1335F). When the doors open up the balls all roll into the blocks.This makes them fit into a much smaller space in the box. Now, if you just set the box down and go to bed, the blocks and balls don't really like being crammed into such a little space in the box, and when you aren't looking they line back up into rows of balls and rows of blocks.(This happens with slowly cooling the steel , and is annealing.) Now that is fine (fine pearlite,to be exact), but every time you move the box, they dump out easily (soft). You can't take the box to Grandpa mete's house because they fall out in the back seat ( won't hold up to wear). So Daddy Kevin tells you a second secret word,
Ms (450F). When you put the toys away,you say this word, and the secret doors open up with all the balls getting between the blocks ( quick cooling), with a ball touching on every side of a block. This way they are packed so tightly against each other and the box walls ,that they don't fall out of the box. But there is still a slight problem, they are squeezed in so tight the box could explode if you toss it in the back seat of the car too hard (steel breaks easily). Daddy Kevin says to give the box a few gentle taps (tempering), allowing the blocks and balls to find a slightly more comfortable arrangement that still stays in the box (hard) but won't explode if you drop the box (break easily).
Now,Daddy Kevin never misses a chance to teach you a little science, so he has you look close at the blocks and balls. See, there are still only 50 of each, but some blocks are just touching other blocks (iron) while others are in tight little clusters with the balls wedged between the blocks (carbides). This is how Daddy Kevin wants you to keep your box of iron and carbon. When you get bigger he will show you how to deal with having more balls than blocks ( hyper-eutectoid), and what happens when you have other shapes, like triangles, added to the toy box (alloy steels).
Now go to bed and have sweet dreams of forging. (Some of you may need therapy after reading this).
Stacy
jdm61 - Surely you know who Frank is?
