Free Form Sharpening Angle Help
Wow. Came across this. Take the angle you want on a side and enter it into angle A. Take the width of the blade and enter it in to side C. Hit calculate and voila...the height to hold the spine off the stone. Obviously a knife blade tapers but this seems like a great head start.
Mods, if this is inappropriate, by all means shut me down.
http://www.carbidedepot.com/formulas-trigright.asp
Yeah this is useful for those annoying calcluations. On a calculator this would be (blade_width) * sine(grind_angle)
egroeg
Thanks. Actually, that is what I was looking for...the formula. I got an A in trigonometry...30 years ago. I was looking for the formula and the tables and I found this which does it for you. Thanks for the formula. I shouldn't have sold that text book...it's not like trig is going to change;).
Thanks.
I'm not a trig expert so I have no idea why, but I've found on most calculators what you actually want to do is this
A = asin(d/w) * 180 / pi
A = The resulting angle
d = Distance from spine to stone
w = width of blade
Multiplying the answer and dividing it by pi converts radians into degrees.
knifenut pointed out to me that you want to measure "d' from the center of the spine. So what I do is I measure with a caliper putting the frame on the top side, and just subtract half the blade thickness so it reads as if it were from the center axis. Then with "w", you want to measure it from the point where you measured "d" to the knife edge.
I don't know what kind of precision this has but it's worked pretty well for me in the past in trying to figure out where to hold the spine to match a factory angle.
Hmm. And all these years I thought the center of spine to stone measurement was just about this much. If it wasn't this much, it was always that much.
OK trig wizzards, how do you hold that "measurement" anyway? Especially around the belly and up to the tip?
Take it from and old timer- thin the bevel out until the edge starts failing while you do what you normally do with your knife. Make it a little steeper than that.
That formula never fails.
I'm with grizz. That's a neat calculator, but I'm still going with what I was taught: raise the bottom side of the blade a distance equal to the thickness of the knife. This gives a pretty thin angle that's usually still strong enough for reasonable work. Plus, thin knives turn into slicing monsters and thick knives have an angle appropriate for harder use. Just my $0.02.
Well, I've mostly used it when I want to grind a factory edge without re profiling, but when I want something static that I can keep as sort of a "reference" to come back to after a bit of grinding. So typically I figure the spine height that I need to match the factory angle, and then use spacers like pennies or something similar to make my static reference.
It's also useful if you want to know the angle of a knife that you've got from a customer.
I mean, in both cases, the marker trick would work... But I've found that there's less trial and error by using the calculations than marking the blade, trying an angle, raising a little, marking it again, and so on and so forth.
It just helps out a little bit. It's also fun for those academic kind of pursuits if you're messing with a blade. You can get it to some angle you like, and then what? How do you know which angle it was? What if you wanted to try it on a similar knife?
I mean, I know there's plenty of things people have done that makes knowing the exact angle kind of unnecessary, but it's still nice to know in a lot of cases. One thing I could think of is if you're posting here on BF for advice, and someone asks, "What angle did you sharpen to?" What if you don't know if it's 10 degrees, 15, or 30? The biggest reason I like to do it with spine height is that I can't estimate what angle I've got the knife at very well once you get down past about 30 degrees.
Really, the "trig" is just a more complex way of doing what a lot of people already do by determining angle with spine height. I remember watching or reading something that said with a 1" blade you could calculate the angle by raising the spine 1/16" at a time, and I learned the penny-stacking trick off of a Japanese cooking cutlery DVD. Using the trigonometry may make it seem like it's trying to be much more accurate than it needs to be, but there is actually a bit of simplicity to it when you realize that instead of messing around with markers or pennies, all you have to do is take a couple of measurements and do a calculation.
