- Jun 5, 2014
Hey guys when you are free handing using the burr method. Do you have to have the same amount of strokes on each side of the blade?
Your telling me I dont have to pay for this "hand question"??? Its totally free????
Same for me.100% free of charge. Questions about all other appendages cost $5 apiece.
TGK, I don't count the number of strokes per side, I just work on one side till a burr is achieved then flip over and repeat. :thumbup:
There's no need to do the same amount of strokes on each side. What you're trying to do is balance two things:
1. Keeping the edge bevels symmetrical. This is actually composed of at least 3 parts, but I don't want to over complicate things just yet.
2. Forming a full length burr on one side of the blade and then the other.
If your edge bevels are identical, then doing the same number of strokes on each side is a good idea, but you still have to form, detect, and remove the burr from each side. Most bevels are not identical and will require more work on one side than the other. Most bevels will also require more work on *part* of the bevel than the rest.
Balancing #1 and #2 above for me, means looking at my edge bevels from time to time and switching sides when they are getting close to the same. Then alternating "rounds" of grinding on one side, then the other, until I form a burr on one side. You can just grind away at one side if you want, but you'll probably end up making your bevels asymmetrical if you do: One side will be wider than the other.
Brian.
