What kind of knife, are the sides flat like a kitchen paring knife, or angled?
Do you care if the sides get scratched up?
Do you know the existing angle?
For my freehanding , because my kitchen knives have flat sides, I use a ~15 degree paper wedge (its covered in tape)
since I put the wedge on the stone, the size is in centimeters/millimeters
## angle( 15.00* ) >>>run ( 05.60 ) |||rise ( 01.50 )
i put it on the stone, lay the knife on the wedge, and that is my angle that i want
The other way I freehand is use the sharpie permanent marker, and then go finding the existing angle , basically try stroking at some angle, and see if you're removing most of the sharpie ... if you aren't change angle ... then that is your angle ... then I go make a little paper wedge for that knife
you can also find angle by touch, you start stroking with low angle, and keep increasing angle until you notice the blade bite into the stone, then back off a little and thats your angle, but like sharpie, you gotta keep doing it over and over and over every time you life knife off stone... paper wedge makes this easy
similar to wedge you put on the stone, you can put the stone on a wedge/incline, then the stone is at an angle, and with your knife you simply stroke/slice horizontally
thats it for freehand angles , just make sure you look at where the blade is contacting stone to make sure you're making contact ... its funny but if I don't i'll start doing all kinds of weird wobbling moves
if you want to not scratch your knives, cover the sides with tape, or go really really slow
so basic sharpening procedure (not burr based)
1) remove the fatigued metal , cut into the stone, now look at knife edge, it should reflect light (use flashlight if you have to)
2) then you put on wedge and stroke until light stops reflecting (or starts to stop reflecting), then slow down and do slow careful strokes... try slicing newspaper, pretty soon you'll be able to slice newspaper, when you can stop
3) raise sharpening angle 5 degrees and lightly lightly sharpen one two strokes per side, and you're finished
this gets me slicing effortlessly newspaper ... also scrape shave a little or a little more ... people on the internet report this can get you to push cutting sharpness but I'm not that good
