grobe said:does anyone know the approx. temps that steel would start to become brittle??
grobe said:nice trick cybrock-
i was wondering if a properly heat treated camp blade of say 1095 or 5160 should or should not be used for general purpose chores (chopping/splitting) at temps of about -75F.
cybrok said:Easy trick.
You can feel it with your tongue, I learned in my Material Resistance class that when steel become fragile, it take a very special texture.
But your fingers, especially if they they are cold, won't be able to feel it. Only your tongue will be sensitive enough to feel it.
So I suggest you try it.
grobe said:not going anywhere that cold. just wondering how steel would fare under normal use in those kind of temps. people talk about ti not becoming brittle in extreme cold, and i was wondering when steel becomes brittle. i know in these kinds of sub-freezing temps, most chores for a knife wouldn't be needed. just kind-of curious as to the 'numbers' of it. i admit it's probably very rare, but there may be a situation where one would need to use a knife, or more likely, an axe under these conditions. does anyone have a figures on when properly heat treated steel becomes fragile due to cold??
thanks
mete said:Maybe Cybrok means that if you tongue sticks to the blade it's brittle ? LOL Actually the Brittle Transition Temperature depends on chemical composition and can be as high as 70 F !!
