- Jul 8, 2002
I have a 2 HP 3 Phase motor that drives my grinder. I think if I lower the speed of my grinder when using the finer grit belts, I can have better control of my hollow grind. Right now she runs at 6000 sfpm.
I have found a used ABB variable speed motor controller, but it does not exactly match my equiptment. the controller's input is 380/440V 3 Phase. My input would be 230V 3 phase. The rated output amperage is lower than what i would need, but if I can run it on 230V instead of 380V, then the output current should drop right into the range i need.
Would it still work, or should i shop arround some more?
