- May 28, 2004
There is the last one
. A mini friction folder inspired by Pao (Paulo Simoes) Work. The blade is the same that i made for olmo that was inspired by the design of oufti that i used for the kitchen set for my sister. To resume i took some idea that i like, shake everything and obtain that little FF.
Weight 32 g
Closed 9cm to the queue (7 cm without)
Open 11,6cm
Blade 6 cm usefull 5 cm. O2 differential hardening, tempering 1h to 220°. 3,2mm of thickness
Thickness : to the pivot level 9 mm to the high point of the handle 9,5mm
Folded Ti handle. Anodised with torch (to obtain something less clean than with electricity).
I brushed with dremel steel brush at the pivot level in order to obtain a variation of color
Two little washer very thin are in place and the friction is important. No problem
It's rasor sharp. (it's not vey easy to know but it's my calf because my arm and hand havent no more hair
http://s139.photobucket.com/albums/q314/cardoso5fr/?action=view¤t=DSCN2235.flv
What do you think about that baby?
Weight 32 g
Open 11,6cm
