- Feb 4, 1999
I am playing with the idea of making a friction folder. This would be the first knife I have done on my own. The idea comes from Wayne Goddard's articles, of course, but I did have a few questions... I would assume the following design: blade, pivot pin, stop pin, open back if possible, dual stainless liners, and scales over the liners. The questions:
1) What material for the liners? I have a sheet of pretty thin stainless, but I don't know the "pedigree". Probably 300 or 400 series. Is this good enough?
2) What size and material should I use for the pivot pin and stop pin? I have a good selection of stainless rod stock available at the hardware store, as well as "music wire" which is hardened carbon steel.
3) Should I consider a pivot screw for adjustable tension rather than a pin?
4) Should I use screws or pins to hold the handle scales in place? I don't have any tapping equipment. Also, in terms of using screws, how does one countersink the area around the drilled holes so the screw head fits below the surface of the handle material? Is it sufficient to just use a larger drill bit and drill partially into the material or would I need some sort of bit that does a more precise job? I do have a drill press, now, so that helps!
5) I had trouble understanding Wayne's drawings. Where does the the friction to keep the blade open come from? Will this type of folder have slow, resistant opening?
6) What should I use for washers, and where can I get these materials?
Also, if anyone has any materials they would care to donate for this project, please let me know. I would compensate shipping and possibly trade services for the stuff. I think all I really need, assuming my liner material will work, is a piece of steel for the blade. i was thinking of something fairly short and broad. A piece of steel around three inches long by 1.25" wide or so would work fine. I want this knife to cut well, so I would need it to be pretty thin. I also wouldn't mind something like 01 or 1095 or something like that that I could heat treat myself using crude methods (i.e. torch and homemade quench). Stock of 1/8" or the nect thickness up would be fine. Also it would cut down on the amount of work I would have to do to make the blade, which will be done with hand tools and a little help from a 6" bench grinder with a 60 grit wheel. Anyway, this is a side-project that will take some time, but if you have a scrap of steel that will work for me, I would gratefully accept! Any information would be much appreciated, too.
My Custom Kydex Sheath page:
http://www.geocities.com/CollegePark/Lab/1298/frames.html
Palmer College of Chiropractic
On Two Wheels
agocs_s@dd.palmer.edu
Madpoet (Mel Sorg, Jr.) Tribute page:
http://www.geocities.com/CollegePark/Lab/1298/madpoet/main.html
On Two Wheels
