Friction folder
I've got the urge again. I have always had trouble cutting the slot for these things. I would be grateful for any tips.
Thanks
Best way I've found for slotting wood is with a table saw and a good miter gauge. Have to make a jig.
Need 2 peices of 2X4 or something that you know are good and square. Cut one 2 inches shorter than the other and screw them together so that they're flush on one end.
Using a large C clamp, clamp your peice you want to slot into the jig so that it butts up agains the end of the short peice the is back tight against the longer one.
If your blade is good and sharp, you have a sturdy miter gauge to clamp the jig to, and you take your time, you do a surprisingly good job ripping slots into thin peices.
For a friction folder I guess it would be a 2 part process. First slot the depth of the handle lengthwise to keep the solid back.
2nd turn the handle on end and raise/lower the sawblade to cut out the front of the handle where the blade sits.
Another option would be to start out with a wedged shaped peice and slot it lengthwise.
Peter, you mite drop Gene Chapman a line. I think he makes his own
saws. When I made them I used a over size cut off wheels made
for the Dremel. But I have alwas wonder about a Slitting saw that you use on a mill
Several years ago I bought a Dremel table saw. The little rascal is great for small jobs, but still has enough power to cut 1" or better stuff. The blade needs to be sharpened, but it turns so fast it will still do a slow cut.The saw blade is pretty thin and works perfectly for small cuts like you describe. And yeah, I would think the slitting saw blade would do a good job if material is slow fed into blade.
Thanks everyone...
Ripper, I went and looked at that thread. I went to Gene's website also and got educated somewhat. I'm looking forward to starting this one.
