FRN handles & "tired" locks
What are the symptoms that tell you to replace your knife (or turn it into a trainer...) .....how much blade play is acceptable when the blade is locked out?
What part of your question did FRN play?
Can't answer your question on blade play. None of mine has ever developed "excessive" blade play, so I don't know when I would retire one.
The answer to this question is "when it is bad enough to post a question about it on the internet.""when is up & down blade play" considered excessive....
It might be possible to get someone to answer this question, but you still have not posted the exact model of knife that you are worried about and as was mentioned above, a certain amount of blade play might be OK in one case, but might indicate a mechanical problem in another case. So, if you are not willing to have your specific knife examined by an expert, the real question is, "do you feel lucky?"![]()
Well, I was hoping for something a little more "quantifiable"! For example, even the MBC Spyderco's have some blade play and it is considered normal (if I remember some post's from Sal correctly)...so how much is excessive?
