From black to blacker and more shine?
mthall47
BOUNCED EMAIL: I need to update my email address in my profile!
Crazy question here.
A lot of the knives I am interested in for my next purchase all have non reflective black blades. I have only a couple of very shiny, reflective black blades which I like, but not in a knife I want.
IF I get a non reflective black blade is there a kind of polish I can use such as Simichrome, Flitz, Metal Glo, etc, that would make the color become a deeper, richer black + add some shine?? SOmeone locally said to try black shoe polish but do not know how that would work on metal.
It is simply a matter of looks.
Please give me your thoughts on this.
Thanks. :eek:
i am no expert - im sure a knifemaker can give you more info (although not many handmade blades are black coated, heh).. but if the blade has a crinkle-coat on it then it is designed for durability of the finish - to slow the wear of it during use. if you were to polish/smooth it you would be shortening the lifespan of the finish. many also assume that a finish is sprayed onto a gleaming perfect blade: this is not usually the case. often a finish not only protects, but hides a dull blade and imperfections. most of the time its just a matte finish on the blade, and the coating is then sprayed onto that. many finished - like TiNi will go on glossy on polished surfaces but will go on very matte on bead-blasted or unfinished surfaces.
personally, im not a huge fan of coated blades. i use pretty much every knife i have at some point or other, and with a black finish the first few serious cuts are going to leave scuffs/scratches on the blade. so if you want all of your knives looking perfect, you might as well just never use your black coated ones, heh.
with a black coated blade ill usually just go out into the woods and hack away with them a bit, to 'break them in' and start wearing the finish. from that point on i no longer worry about how the finish looks, or protecting the finish :)
Depending on the coating, you might be able to use a high grit (1200+) sand paper and give it a light, uniform scuffing. That should give it enough of a dullness that it wouldn't catch light. I wouldn't go any lower grit, as you might sand more away than you'd want to. DLC coating might be rather difficult, since that stuff is very tough.
WD40 makes some black finishes shine like ya are talking about, thats the only thing i know of.
Er, I notice now that I gave you the complete opposite advice you were asking for. Whoops.
I've gotten my Benchmades to shine a bit more by using Johnsons Paste wax. A floor type wax. Car wax also will work.
Paste wax smooths and fills the surface to give a smoother more light reflective surface. I suggest a non coloured paste wax like Renaissance wax or Johnstons paste wax.
