My paramilitary 2 was screaming sharp last night. I cut one rope and I'm sure it would have a hard time cutting through butter... why so?
Once you get past 2000 or even 1000 (if not a strop) you are going too far. You remove too much material and make it brittle. 800 or 1000 is as far as you should be going
Well it had DEEP scratches from the diamond stones that were bothering me so I cleaned then up with the Ken Onion Worksharp. Once the scratches were gone and the last 1/8th of the blade was even I moved on to the KME and the chosera stones.
I belive my problem would be that on the KME I spend some time on each side and don't really alternate stroks. Like 20 and 20, simply because I dread flipping the knife. Getting closer and closer to pulling the trigger on the WE
But do guys think the edge would be lost after only one cut? The Wicked Edge would allow for strokes on both sides reducing a formation of a burr.
10k is for Straight Razors not knives. Knives need that toothy edge because most things you cut are very abrasive, meaning it will wear down a finely polished edge in as little as one cut. The coarser the better.
