- Mar 5, 2003
I need help in understanding the process of blade making in general terms.
I will start with what I've heard.
First you start with sheet material from the material supplier. It has to be relatively thin so it may have been cold rolled and later annealed to a starting condition and hardness level.
Then the sheet is heated up (temperatures vary by material) and open die forged or hot forged (?? more info on this step would be greatly appreciated). The open die forging gets the blade into a rough shape.
After this point some machining takes place.
Once the blade is in form, it is heat treated.
Then it undergoes final sharpening.
Is this general understanding correct? Can someone help fill in some details? THe more the better
Thanks in advance
Thanks in advance
