Try doing a search for powdered metal damascus tutorials. Excuse my crued explanation. ist you take a mild steel thin wall tube say 2 x 2x8 weld an end on it, fill the little can youve made with powdered 1084,and your damascus scrap, fill the can help it all settle by tapping the can or vibrating or compacting, drop a small wood chip size of a pea on top of the powder mix, weld another end on so you have a sealed can,weld a handel to the end on the unhandeled end make a weep hole to vent gasses or leave a weld void, stick the can in the forge bring it up to temp so it looks like a cube of butter, and forge it out trying to keep it square as you go, best done with a press, I imagine you'll end up 1x 1 x 14 at that point you could accordian cut it on the sides with alternating band saw cuts from the side say 3/4 an inch apart, stagared from to sides, heat to yellow grab the two ends with pliers and pull it aapart to make it somewhat flat, forge to make flat. The possibilities are endless. I personall have not done this but have helped three other knife guys create, billet this way..
