Assuming identical steel and heat treat, which would perform better? I would have the Norwegian grind set up for an included angle of about 25 to 30 degrees. This would be for a smaller knife, (3-5 inch blade) used for general cutting tasks; i.e. whittling tent pegs, slicing edibles for camp, cutting cardboard, cleaning deer or fish, etc.; in short any normal fixed blade cutting activity. To go with cutting performance, would edge holding be significantly different? For most cutting tasks, edge rolling most likely would be more of an issue than actual wear, I think.
It seems that as long as you dont let them get too dull, convex ground might be easier to sharpen, using the cardboard trick, but could this also be done with the Norwegian grind? What about if for some reason you let the knife get pretty dull, which would now be easier to sharpen? My guess is that convex would overall perform slightly better, but I am not sure. What are your thoughts? Thanks in advance.
Richard
Richard
