So far as the very edge itself is concerned, I have found it simpler to create a shaving/hair-whittling edge with a true V-bevel. That's what's in play when testing on a fingernail (or the 'bite' felt, when lightly running the edge across the skin). But, in terms of how the blade performs after the edge has made the initial cut through the surface of thicker material, the grind of the blade as a whole comes more into play. That's where the full convex really excels. I'm willing to trade off a tiny bit of the shaving sharpness, for the true effortless slicing afforded by a smooth convex grind. In real-world use (anything other than whittling hair), it makes for a very, very useful cutter.
And I've found, the more I practice at it, I'm getting closer to achieving the 'hair-whittling' capability with the convex edges. If done correctly, even a fully convexed blade will still have what amounts to a sharp 'V' at the very edge. Anything 'round' just wouldn't be quite as sharp.
