Full damascus Coffin bowie with mammoth ivory - W.I.P
Petr Melicharek
Hi everyone !
This week i just started an interesting project and i decided to take some pictures :) If everything goes well, at the end there should be so called coffin bowie. The picture is just a very simple draw of an idea . I have majority of the things in my had :) The customer gave me pretty free hand. He just demanded type of the knife (coffin bowie), full damascus , mammoth ivory on handle and Spanish notch. I decided to go for twisted W pattern. Well, life is to sort to make simple damascus patterns :D Just joking:) This will be pretty challenging for me and lot of things may came out pretty bad. So wish me luck friends ! :) We are starting !
First three days - damascus welding, blade grinding
I prepared two 2,2 kg (4,85 pounds ) billets . Just to be sure that i wont go short :) I will make another blade with rests, if there will be any. You can see how long was the billet after pulling it out :) it was like my leg .. :D almost 80 cm (31 inches) 30/10 mm (1,2/0,4 inch). For bad luck , batery in my camera died just before welding and i forgot to charge it another day:/ .. so i decidet to use pics of another twist i made few months ago . I dont have pictures from grinding blade either :( But as i can say the blade came out nicely, pattern looks pretty cool but for now i decided to show just a siluete of roughly grinded blade :) The notch needs bit more work to make it nice :) See you next time with another part. PM
Definitely want to keep an eye on this WIP
Sent via telegraph with the same fingers I use to sip whiskey.
Thanks a lot guys !!! :)
Here comes the second part - The guard
Hi everyone :) After couple more days i have a guard shaped more or less. It is made all by belt grinder, angle grinder and dremel . Now it is time to put it into perfect shape by hand, using sandpapers and diamond files. It is already quenched from start . It is full damascus twisted W pattern too as the blade is, but i wont show it until whole knife is finished :) . So what do you think ?? :)
you are really off to a great start. The plan you drew looks wonderful. The profile of the blade came out just right. Now, the guard looks good. I am enjoying this.
Question, weren't a lot of the coffin handle bowies either full tang or frame handle?
thanks for sharing this. I am enjoying it a great deal.
Thanks Kevin :)
Yea i think it is as you said. This one is going to be frame handle :) I will show in another part ... Stay tuned :) PM
Hi everyone : After some days of "cursing " and fitting all together nicely here comes the part 3 :D
I already made the cage for the handle that is typical for this kind of knife. The spacers are damascus and the "wall" is carbon steel . All the parts are quenched on this knife to get the nice contrast on damascus. :) The service holes with the screws will be hidden beneath the scales :) To be continued ..
Excellent WORK-IN-PROGRESS photographic documentation, Petr Melicharek!
Beautiful work too!
All the best,
David Darom (ddd)
Thanks a lot guys:) I appreciate your support :) in few days ill post more pics !
Hi everyone . I made rough grind on ending nut. I couldnt decided about the shape so i just grind it roughly and i will decide latter when i see it on the knife :)
Second part shows the scales fitting to the handle . Personally i find this part difficult for me . As im used to work mainly "from hand", hardly measuring anything and working just with my feeling this results bit harder for me :) With all those rivets every hole drilled and every angle has to be perfect .. if not it would look very disharmonical on the finished knife . I just wanted to make some tests so i made pair of "help scales" from oak :) Just to see if everything goes nicely . I just post these as i wan to concentrate when working the mammoth and not bother with camera :) see you with next one :)
