would someone who has done this before review the following and correct me where i go wrong. i got one of mr. martino's scratch-and-dent kukuries, and instead of repairing the handle i would like to replace it.
1)remove the 'eye' on the buttcap by wiggling it back and forth until it pops off the tang. use a mallet and coldchisel or big screwdriver tip to encourage it.
2)boil the whole handle up to the bolster to loosen the lasa/goo they use to glue the handle assembly. this may take 15-20 minutes. when the stuff is sticky again, pull all the parts off the blade, being careful not to burn yourself. you will be left with separate part now -- blade, bolster, handle, cap, eye. clean lasa off any of these you plan to reuse.
3)make your new handle and reassemble, using the glue of choice. before the glue hardens, peen the tang over the eye by whacking it carefully on an anvil or other polished metal surface. you want it nicely and evenly rounded over.
what would you use for glue? i would prefer something that could be undone/redone like the lasa, in case the handle cracks or breaks. epoxy, is, i think, forever, and would leave you with one heck of problem if repair was necessary.
what would you use to clean the parts? does laquerthinner dissolve the lasa? i want to make a nice job of it.
thanks in advance for any good information
ab
ab
