- Jan 5, 2015
I have made a number of knives of various style in the past 18 months, but all relatively small and not with a full height grind. Momma wants an 8" chef's knife which will be much taller (aka wider) at about 1-7/8". Most of these type of knife designs (including the factory made one in my kitchen) have a full height grind. I have always put grinds on by hand (ie, not with blade clamped in a tool to steady it as it is slid across the 2 x 72 belt grinder). Today I took the 8" chef knife from my kitchen and simulated pulling it across the grinder (with the grinder off) to match the existing grind - knife edge facing up, belt traveling downward). My two fingers on the spine (bottom) of the knife get REALLY close to the belt. Starting stock thickness of the 440C will be 3/16" and the final max spine thickness should be about 1/8" at the handle. Thinner out near tip due to distal taper which is planned. So, not a lot of spine thickness to hold the knife when putting on full height grind if I try to do it by hand. Is it more common to make a tool and clamp the blank in the tool to make a grind like this? Thanks in advance for your advice.
