- Jun 27, 2016
Working on a set of hunting knifes. I'm trying to attach handles and I'm having issues. I have 6 hardened blades with pin holes already drilled. I numbered each blade and each set of matching micarta scales. I flatten the scales and then super glue the scales together and then super glue to one side of the knife. I drilled (drill press) all 6 pin holes on each blade, adding 2 pins, one at each end and edge/spine side as I drilled to keep the blocks from shifting. I cut out the handle outlines and finished the fronts to prepare for glue up. Here coke the problems.
None of the handles now mate to the knifes. Some holes are canted, even though the drill press is square in both dimensions and my handles were parallel to each other and perpendicular to the drill bit.
Some holes don't even line up, if I put in one pin, 1 or 2 of the resulting 5 others holes are off by almost a pins diameter.
The pins don't fit in the micarta after drilling neither does the drill bit, it's like the holes shrunk. But I don't have a one size up bit for .094", so I can't even dry fit handles bc it takes a press or hammer to insert pins to the micarta and this has been bending my pin stock.
I tend to stick to hidden tang and I'm really remembering why that is but is there a step of my process that's sounds off that I can change to fix this or something y'all see that's wrong?
