Erin Burke
KnifeMaker...ish
- May 19, 2003
Base on recent post to his instagram feed, I'm fairly sure that Matt Gregory will be of no help with this question
... but for the rest of you...
... What are your tips/tricks for cleaning up your fullers?... particularly the ends of your fullers.
I occasionally like to throw a fuller onto a knife, but I'm not to proud to admit that they can be a pain in my @$$. With a little help from y'all, I'm hoping I can take some of the sting out.
So how am I currently doing fullers? Right now I mill them using ball nose endmills. My first goal is to get the cleanest finish I can directly off the mill. To my novice machinist's brain, this means a final cleanup pass with slightly higher rpms and SLOW feed. But even my best milled finish leaves tool marks that need to be cleaned up... which I take care of with sandpaper wrapped around a variety of round implements.
In the photo below, I milled the fuller with a 3/4" ball nose, and have started hand sanding. For this example, I'm using a little sanding device made from a chunk of flat bar tacked to piece of round bar of the appropriate diameter. The whole thing is covered in an adhesive-backed cork.
As noted in the photo, the real pain is getting the tool marks cleaned up at the ENDS of the fuller.
What do you use for this?
So far, I've managed to live my life without Cratex, but I'm wondering if a nice rubberized abrasive cylinder in my Dremel might be the ticket. Is anyone doing this?
My priority is to keep the fuller crisp, and I'd prefer to avoid anything that washes out the edges.
Thanks in advance.
Erin
Thanks in advance.
Erin
