- Mar 16, 2012
Hi all
I apparently have too much time on my hands.
I've been playing around with diamond paste on balsa wood, pine and poplar. It's worked ok but nothing to write home about. Probably more to do with me than the materials but I do use a strop with black/green compound all the time and have learned to do it rather well.
Well I was also thinking about my Lansky system...actually thinking about buying the Wicked Edge system and looked at the packages and cost of extra hones?...wow expensive, at least more than I want to spend. I like my Lansky system a lot and get good results...but...I'm dissatisfied with the jump in grits. I use the coarse diamond hone for reprofiling along with the medium and generally start a sharpening with the fine diamond/600 grit followed by the Arkansas hones (650/1200 grits) finishing with the yellow/1000grit and blue/2000grit ceramic hones, finished by stropping with black/green compound. That's a large jump and I'm not satisfied as the scratch marks are obvious under a microscope...damn those magnifying thingys.
So I decided to experiment with some wet/dry sand paper. I bought 800/1000/1500/2000 and 2500 grits. I have some very nice double sided tape from work and a couple of old Lansky hones. I cut the double sided tape and paper to fit the hones and after giving my ZT 770cf some work with the 600 diamond hone to fine tune the edge I progressed up the grit scale using the wet/dry stuck to the hones.
I'm very pleased with how the edge turned out. Each progressive grit improved the edge and the polish towards the high grits. I gave each side 200 strokes, 100 at a time, before moving on. By the time I hit the 2000 the edge had a mirror polish and very smoothly shaved telly book paper with no grabs at all. The 2500 grit did not seem to increase the polish over the 2000 to the naked eye or my 16x loupe. I'm looking forward to looking at it under the mic when I go back to work.
I really did not expect the wet/dry to work so well and I'm even more happy with how it has improved the Lansky at such a small price.
The edge is a mirror. I'll add some pics in a day or so. I'm very impressed, not only with the polish but the finer edge.
Sorry this is a bit long but perhaps this will cause others to experiment and improve their skill levels and edges without spending a lot of money...
