Fun with Acid
Here is a new one that has a deep acid etch using a resist on the edge.
O-1 Flat Ground
Stabilized Maple Burl
Mosaic and Stainless Pins
OAL 8 3/4"
Blade 4 1/4" Tip to Handle
Thanks for looking.........Robert
I hear you loud and clear!!! I love that temper!!!! :D
Could someone explain the "resist", also what is a good sequence for an etch. Shape the handles-etch-then glueand pin???? How do you do it Roosko. Thanks
Ranger:
Here are a some explanations that I posted on another forum--------
"This blade was edge quenched, and the initial acid etch just didn't bring out the temper line like I wanted, so I decided to play a little.
I used Ferric Chloride mixed between 2 and 3 to 1 (1 part FC and between 2 and 3 parts water). Initially etched entire blade for 15 minutes.
Took it out and sanded with 600, then etched for another 15 minutes.
The third etch was for about 20 minutes after I put the resist on the lower portion of the blade."
"The resist was made utilizing state of the art materials. I used some of the prettiest red fingernail polish I could find.
Then just used lacquer thinner to remove it after etching."
Hope this helps.
P.S. There is another pic of the knife with the finished sheath here: http://www.bladeforums.com/forums/showthread.php?t=324638
Robert
