Further Adventures from the Crazy A Homestead (Longish)
Greetings fellow sufferers of HIKV, Hopefully I can get some pics up and running so you all can see just what I have been putting a number of HI and non HI products through.
Background ( for the newbies): Purchased a house up in Tulsa OK. Property had been neglected for ten years and used as the local illegal dump, managed to put a ding in my new M-43 blade when I discovered a cog up in a tree covered by vines........
Lately we have been doing some pretty heavy lumberjacking and vine hacking in order to discover the property line boundry in order to plan the fenceline. Even invested in goats to help chew thier way through the worst of the vines, (Poison Ivy, Wild Rose, Greenbriar and Honeysuckle (?)) Kuks have been worn acting as small belt machetes to cut through the low overhanging vines and small limbs. And the damage from one of the worst Ice Storms to hit this area in a long time. Trees bent over double etc.
Right now the Kukris of choice have been a 16.5 WWII and a non HI (when I start getting too close to metal, As in what happened tot he M-43) this thing has chewed up what ever I get into. If it looks too big I either get an axe or I trek up the hill and get either the M-43 or the Dui Chirra. I have even been known to wear both the WWII and the M-43 front to back. Talk about something that'll pull your pants down :)
Main brush has been small diameter ( <24") hardwoods (Oak,Hackberry, Mulberry, Elm and an unidentified hardwood) all wrapped in various vines. all the kukris have hacked through what I need them to do and in various stages of seasoning ( completly green to completly rotten)
As we fell the trees (normaly with an axe) we pull them and pile them up in the backyard. Mama decieded that it was time to start cutting the piles into firewood so she can walk to her garden with out tripping and falling.
Out comes the WWII and a CS Trail Hawk and a Chineese boys axe with a replaced handle. I normally use this axe for delimbing, well the handle broke again. ( with the use I have been putting it through I'm surprised it didn't go sooner) so I was forced to use the WWII for delimbing. Not exactly my most favorite idea, particulalry since I was with out gloves at this point.
Well it performed in true HI form and didn't give me a lick of problems other than in some seasoned wood that I just brut force powered through. Might have to see about picking up it's bigger brother in a few months. only one knot stopped it in it's tracks but it also slowed down the CS Hawk as well so I won't hold it against it. I plan on honeing the WWII and seeing if anything happened to the edge or not. although I pretty sure it will comeback to it's original sharpness quickly.
I am planning on seeing what the Malla will do tomorrow, since we are mainly delimbing or maybe wearing the WWII and Malla Combo.
Just to give an idea how bad it is I figured out everthing that had broken doing the cleanup
1 double bit Axe handle
1 single bit handle
1 single bit replacement handle
2 Boys axe handles
1 single edged Bush hook handle (original)
2 shovel handles
1 rake handle
1 hoe handle
1 Pole Saw Shaft
1 dinged up Austrian Scythe blade
1 Nubian Goat
after some pretty solid use the HI's are going strong, no loose handles, no rolled edges, no loose bolsters or buttcaps,.
I have had a problem with my BAS with a chipped handle but I think it was a matter of the Autistic one playing with it while I was on the road. found it under a blanket in the tool room with part of the heel that rests on the buttcap chipped/sheared off. But since it wasn't a casuality of the clean up I am treating it as a seperate case. I will be contact Auntie Yangdu about it soonish.
So far the following HI blades have been involved in the clean up
BAS
M-43
16.5 WWII
Dui Chirra W/ Extended tool kit
Malla
I have been very impressed with what these blades have put up with and still kept coming. Hopefully the financial deities are going to smile on me and I will be able to add the 18" WWII to the mix and see what it can do.
I will try to get some pics and hopefully video up and wait to hear back from the HI family.
Ok gotta go, Mama's paging me
Marc Adkins
I was wondering the same. :D
Thanks for the report though! Always fun to read about khuks in their natural habitat.:thumbup:
How the goat got broken is actaully a tale of two injuries. we had turned him and his brother out into the back underbrush to eat away at all the vines I mentioned, couple of days later we noticed he had an injury around his back (left ?) hoof. We don't now what happend, started hitting him with antibiotics but he ended up losing the hoof around the ankle. So Now I have 3 legged goat hobbling around eating underbrush (So he is still usefull) that is full of antibiotics ( so he can't become dinner). A couple of weeks after that apprantely he fell on his side impaling his right shoulder. Being a prey animal when we went to see what happenened he hobbled off as fast as he could away from us, in the process he opened the wound up further. Shock was starting to set in so I euthanised him using method .303
We suspect that he managed to do a couple of things to his hoof, (This is all speculation) he got his hoof entangled in all the vines creating a tourniquet effect and we think he managed to cut his hoof a bit on the scrap metal we learned was in that area as well.
to give an idea on how much scrap metal we have laying around, the spouse let a recently laid off friend come and take whatever they could haul off, the report was they had managed to score over $500 in scrap metal. And we haven't even started to scratch the surface yet......
Hopefully I can get close up pics on what we have done so far with all the embedded trash laying around, along with Kukris in thier native habitat.
This clearing project has really enamored me to this classic and usefull design that we all are in love with. There are reasons that certain designs last as long as they do.
Marc Adkins
Too bad about the goat. Sounds like you have a helluva project on your hands. If it wasn't such a long commute I'd come take some of that scrap metal off your hands.
It's great your putting the khukuri's to work. I use mine for pruning de-limbing ,brush clearing etc. Don't think I've found a better tool for the job.
Marc Adkins
could have been a snake bite.
that is one helluva project... if I was around the area I'd even offer to help out... sometimes there's nothin' more satisfying and laborious than the hacking of vegetation with a good blade... be that with an ax, machete, khukuri, bolo, or golok...
I had to clear an old overgrown pasture like that once to put up my goat pasture. Now it's like a park it's so clear.
I hacked a rough fenceline and then ran polywire electric fencing.
Once the goats had cleared it out we went back and did the whole thing in 5 strand hi tensile fencing. 14 gauge.
I know someone who is doing a prairie restoration. He had a patch of land (essentially bluffs) where no machinery could get to, but he was able to hire a goat service to get in there and remove the underbrush. It took 3 days for 40 goats to totally clear out the area, so they were indeed worth his cost.
Sometimes the best solution can be simple.
Congrats on the new place Marc!!!!:thumbup: :cool: :D
If you don't mind saying could/would you narrow the area you moved too within a couple of miles either way, such as between 145th E Ave and Lynn Lane, east and west, and between Pine and 11th Street, north and south, fer instince? ;)
If'en it should happen somehow to be in the area I've suggested then you're fairly close too us.
Narrowing it down a wee bit we're between Admiral and 5th Street, north and south and 193rd E Ave and 205th E Ave, east and west.;)
Thx for a Great narrative...
I , too, remember "tymes with goats"....
I must have been around 7 or so... had this wee Billy Goat who, one day, just looked bored, sooo, Well, I hooked him up to my bike (pedal powered) with sort of a "harness".
Off we went... worked OK 'till we hit the vineyard (My Dad was a Welch Grape grower).
Finally the grapevines won and he came to a stop.
Of course I was left at the 1st row 'o grapes, while he tried his darndest to go "sideways"thrue the vineyard...
I Sure wished I had' a Khuk then, cause cutting him and the towed object free from the vineyard was a REAL challange with a itty bitty pocket knife!!
Sand Springs
Hy 97 on the east 177th on the west, HY 412 to the south Osage County to the north
Marc
Similar to what we are trying to do, but instead of running the fenceline then clearing, we are trying to clear so we can run a fenceline. ;)
Marc Adkins
Sand Springs
Marc
Great! Pretty country out there! The mother of my children used to live in that area and if you're anywhere close to her old place I'm really glad she sold and moved outta the area for your sake and well being.:thumbup:
A close friend lived in the same area and was in the same homeowner's association, He and most of the other members weren't too fond of her to say the least.;) :eek: :D
