- Mar 26, 2004
This is a custom order I forged back in February, but I just got to ground it last week.
Chainsaw chains and a flat 3/16" 5160 stock.
Using an electric welder, I welded the chains to the stock (note the cutting teeth)
I made a cannister with a pipe and I made a sandwich with the welded piece and two layers of 304 stainless steel, one on top and one on the bottom, to prevent welding against the pipe (so I can retrieve the ingot easily)
Cannister on the oven at 1300C
Once it welded properly, I took it off the pipe/cannister (no pics of that process, sorry)
You can see the welded piece on this group picture, though.
http://www.aescustomknives.com.ar/images2/arielstuff2_bigger.jpg
Preparation on a new capsule, with an identical pipe, but this time I cut it on the upper corners.
I placed a 2mm thickness asbestos paper as antiwelding barrier, as in this case, the SS 304 would be useless, as the bronze would weld with it.
Cutting pieces of brass.
Placing them on top of the asbestos paper.
Some borax on top.
Some borax on top.
