Jack O'Neill
- Nov 15, 2007
Just a heads up folks , I had purchased some 1/4" brass corby bolts from tru-grit back in April 2022, just recently used a couple to find out that the head on the female side had been drill in about 1/2of the way , my guess when the maker drilled the shaft to thread it they went to deep and drilled into the head . I talked to tru-grit today and they said their whole batch was of 1/4' brass was bad this way . So since from April of last year until now they are that way .
Unless you seat the head deep into your handle material ( the female side ) you risk grinding into the hole . I would suggest measuring the bolt and finding where the hole depth is on the head before setting .
Just thought this may help some folks to not end up with the surprise I did when sanding down the handle .
