- Mar 17, 2010
Why does the G10 handle fade after a period of use? Can this problem be solved forever if dyed with Rite Dye?
Is there any other way to solve this problem?RIT dye definitely fades and quite quickly
Yes. However, it's getting worse and worse after cleaning it.Have you tried simply cleaning it? Windex may help.
BTW, why does Rit dye fade quickly? Can't G10 absorb it?
So oiling is the only way to do.
I’ve seen quite a few Spyderco Waterway knives on the secondary market with chalky looking handles. I’m guessing it’s all the surface area from the aggressive texturing which allows them to dry out quickly (on the surface). Mine did that before I used it, and mineral oil made it perfect again.So oiling is the only way to do.
