G-10 Info Required
Gentlemen:
I'm looking to hand work some G-10 scales. I've read some info but would like to hear from the experts. What is the best method/medium to round off black G-10 scales, (due to the glass content) :confused: ?
Any and all information is very much appreciated
Wear a dust mask and work in a well ventilated area. Rough work it with a file and finish it with sand paper. Or, if you have a router and a bearing guided round over bit you can do it that way. Wear a face shield if you do use router.
Sandpaper- Wet or Dry?
Thanks L6:
Should I use wet or dry paper? I've heard the wet medium keeps the dust down. Any suggestions on # paper to use- Its not a large job.
RAYE:
Wet will keep the dust down. You could also try using a little bit of 3 in 1 oil or some other oil on the sandpaper. When using the file, it might help a little bit to put a little bit of chalk on the file so the file doesn't clog up with the G-10 and stop cutting. If you ever move up to using a belt sander or something to shape the G-10, make sure you don't profile too quickly (I accidentally made that mistake last week). The friction heat will build up and cause your G-10 to burn and it smells terrible, and make sure you wear an actual respirator if you use power equipment on it.
Sometimes after sanding, black G-10 will look a little bit white or lighter colored. Don't worry. Rub some oil (WD-40, Tri-Flow, 3-in-1) on it and clean the oil off and the color is normal again.
Thanx gents
Chang, L6:
Guys, thank you for the help and information. :D
Project starts tomorrow ;)
What are you making, anyway? Making new handles for a folder or something?
Chang:
No nothing special. Just a little touch up ;)
I'm doing a lot of reading and hopefully will jump into making my own blades soon.
Thanks again for the info ! :)
For light touch ups, just sand under slow running tap water. There's no worry of dust and it's easy to clean up.
