DanR217
- Sep 6, 2010
Pulled out one of my safe queens a few days ago and noticed a little light pitting on the double cut finish (at least I think its double cut, are there single blasted finishes?). I had Renaissance Wax on it so either I used too little or it doesn't work that well. I put some MilTec oil on the blade and a little got on the g-10 and when I pulled it out today the g-10 is a little sticky.
Is oil a solvent to g-10? If so how do I clean it off?
I used a little Flitz with a rag on the pitting. It worked okay but there's still some little dark spots. I was considering a cotton wheel with the dremel as slow as I can go maybe? Then again maybe not, a little faint staining might be better than a shiny spot on a blasted surface...
Whatcha oinkers think?
