G-Shock Questions...
I'm shopping for my first G-Shock, and I've got a couple questions I'm looking for some help with...
- A friend of mine has a G-Shock, and when he turns his wrist the light comes on - is that a standard feature? If not what do I need to look for to make sure the one I get has that feature?
- Where's a good on-line source (with good prices) to purchase?
- I'm looking for solar, the automatic light feature, preferably all - or mostly - black, and hopefully a less expensive model... any specific suggestions?
Thanks a lot!
John-Boy
Hi John-Boy:
This recent BladeForums thread had lots of discussion about various Casio G-Shock watches as well as the improved Timex Ironmans and cool new Citizen Ecozillas. As far as your questions are concerned:
  • The automatic electro-luminescent (EL) light feature can be switched on or off. I leave mine off to save battery charge.
  • My watch was purchased as a gift online via Amazon earlier.
  • The thread hyperlinked above has good pictures. You can also visit the Casio corporate page and scroll through the pictures.
Hope that helps,
~ Blue Jays ~
My only advice to you is not to limit yourself to watches from Casio USA. There are many cool watches only made available to the Asian and European markets, you can see them here: http://world.casio.com/asia/wat/. I haven't had any trouble finding these watches on Ebay, some of the G-Shock Cockpit series watches are very nice and not too expensive. Good luck with your search.
Just some thoughts on the solar feature -
Digital watches on plain Lithium cells last years - the Solars will crap out after time since their storage batteries do not last forever.
Although the idea of never having to replace a battery may seem on paper to be appealing - and I've been tempted myself -
the problem is that the "accumulator" of the solar generated electricity is actually a "rechargable battery" - which unfortunately does not last forever and will eventually need replacement.
I'm not sure of the technology used for the storage/rechargable battery -
but we all know NiCd's are terrible - heaven forbid it's one of those.
Lithium rechargables are supposed to be good - but really meant for high drain applications - I had 2 Li rechargable batteries for my Canon digicam - and after 3 years of cycling usage they both gave up the ghost.....
NiMH seems like a good technology - but again for high drain and I'm not sure how they react on slow trickle drain/charge - but even they only claim 500-1000 cycles of charge/discharge - at 1 cycle/day that's only 1+ to less than 3 years - OK maybe it's not 1 cycle/day - 1 cycle/2days average?
still = less than 3-5.5 years - that's still not "forever".
Personally I would prefer a regular lithium powered watch.
On Casio G-Shock Tough-Solars the storage battery is a Casio type CTL1616
(I suspect this is just Casio's own designation for the lithium CR1616 - which is normally used as a backup battery.) -
Seems like if the watch does not get enough bright light - it keeps using the back-up battery - and the watch dies or malfunctions after a few years - much less than one would expect - as these threads seem to indicate -
G-shock Tough solar problem
Casio Atomic Solar watch - opinions?
Anybody played with these Casio watches?
There is a G-Shock Forum where there are some very experienced G-Shock people that you could go ask about features and advice opinions.
Vincent
http://UnknownVT2005.cjb.net/
http://UnknownVT.cjb.net/
http://UnknownVincent.cjb.net/
Cool. Thanks for the tips. So I abandon the solar option... at least for my first one. I've got my heart set on a Citizen eco-drive at some point anyway.
thanks again!
I had a problem with one of my solar models. As far as I can tell, any problems that have popped up is the use of the 1616 battery models. My battery was replaced by a local jeweler who tested the water tightness afterwards to make sure it was not compromised..all for about 10 bucks versus the 40-50 that Casio wanted. One of the many theories (nothing for sure) is a bad batch of batteries and that the problem may not exist anymore in recent production, YMMV.
Solar models are available with a few different battery types though, so you dont have to get one with the 1616...plenty of larger capacity models available.
I think the auto-EL is only available on the solar or 10 year battery models. If its something you will use a lot then of course a standard 2-4 year battery would be a bad choice as the auto-EL drains it quick. I have a few models with the auto and I find I hardly use it. Neat feature but way to sensitive and may require you to need to charge the watch way more often.
I swore off solar after my GW-300 had trouble, but after speaking with the jeweler about it and reading some of the comments on ht watchuseek forums I have given it another chance. Think of it this way, just pretend that the battery will only last 3 years under normal use in either a solor/non-solar model. Frequent use of the light and alarms will shorten the life of a standard one. Even if you only get 3 years out of the solar battery, you can still use the light and alarms far more often without worry. Also, either one will eventually need a new battery anyways and for a jeweler that knows what they are doing, one is no more trouble than the other to change.
As for your needs that yoyu stated, this is one of the ones I think can be useful. I got one recently myself and love it. It has plenty of features, autoEL if you want it, and of course the all important countdown timer.
This uses one of the higher capacity cells and I have not read of any problems with it about short battery life. If you want a solar, go ahead, I dont think you will encounter any problems.
Be careful of ebay. If you find one you like, then check on the seller. There seems to be a high number of fakes (some models more common than others) of G-Shocks and might be difficult to tell if you dont know the watches all that well.
For most models, this place seems to have good prices: http://www.4-watches.com/casio/gshock.html
Never hurts to check Wal-Mart though, some stores have a good selection and by the time you figure in shipping from online dealers then Wal-Mart is probably about as good a deal as you will find.
More great input... thanks a lot!
One more question to add to my list:
I've seen the adapters at counycomm.com for nylon wrist straps... any opinions on those?
Also, look at the thickness of the g300? solar g shock, its fine with me , but a more refined friend pointed out how large the watch is, and he had a valid point.
Yeah, they are thick. The size is what a lot of people like about them. If you want thin and still want a G, the DW-5600 is one option.
The one in the picture I posted has a nylon band with adapters. Not much to say really, just depends which type of bands you like better.
Klesk said:
...some of the G-Shock Cockpit series watches are very nice and not too expensive. Good luck with your search.
I have a couple of the Cockpit watches (G-700D-1A & G-741D-1AV), and find that they are both excellent watches, and are well-worth their price.
The G300 series, not the GW-300, is just about the best proportioned G-Shock I have found yet.
Most G-Shocks are just too thick in relation to the total diameter of the watch, and the bands are a bit too narrow, for my tastes.
Take a look at the G300 "Street Rider" series if you want a really nice G-Shock.
Also, the G2300/G2310 series are nice, if a bit thick in relation to the diameter. Lots of nice functions for the price.
The Timex watches are very nice, except they are not very impact resistant, which is why I switched back to G-Shocks yet again.
Another problem I encountered with the Timex watches, especially the 5F8XX series was quite a bit of LCD ghosting, even at pretty steep viewing angles.
Best to take a look at one in person if you are considering one of these models. Of course, the reverse display model would not have this problem.
