G10 flow through?
This should be an easy one. I am looking for a good quality folder that is pillar construction, flow through with full G10 (ie no steel liners) frame. Suggestions?
I must be having a brain freeze, because the closest ones I can think of are the new 2011 designs from Kershaw that have full G10 and a small steel tab lock instead of a full liner.
Now that I think about it some more, nearly any locking mechanism in existence would make it not be "full G10" in an absolute sense. I suppose you could have someone custom up a full G10 pillar construction friction folder.
I don't think that exists.
You can give up one side of the handle to a slab of steel or titanium and get something like a spyderco leaf storm, or strider sng.
Or you can have two steel liners, but get g10 handle scales with pillar construction out of a benchmade axis lock knife
Or you can give up on the pillar construction and get a CS Triad lock knife.
A liner lock or frame lock will have to have some form of a steel liner on the lock side, even if its just a partial liner.
An axis lock will also have a steel liner for the bar to ride on.
A friction folder will allow for you to have full g10 handles with no steel liners and pillar construction but you won't have a lock, although there are some pretty trick designs out there that will be even more secure in use than some locking knives.
Closest I can think of is the Kershaw Skyline.
It has steel liner lock on one side, and does have spacer in the rear half of the handle.
Yeah that's the thing, right? The lock. That's why I couldn't come up with one now that you guys mention it. I do have a SMF which is what got me thinking of it. Hmm.
Brian Tighe Coone. He makes one with carbon fiber without liners. I'm sure he can make one out of g10. It's a button lock. I had the privilege of handling a few of them at Blade Show 2010.
Will cost ya. Tighe's a very respected custom maker.
Alan Elishewitz/Hogue EX01 G-Mascus has no liners except for inner steel bolsters at the top of the handle. It has a flow through design, but not quite the type you are looking for. Alan Elishewitz also makes the MTK which has linerless G-10 scales with inner bolsters like the EX01, but the MTK makes use of a small backspacer where you are looking for standoffs.
