G10 Harpy: A Good Thing
Just got a slightly used G10 Harpy and I'm generally impressed.
The blade is a little shorter than I expected, and the steel is a little more difficult to sharpen than I expected, but the knife is also truly overbuilt and it's more of a quality piece than I thought it'd be.
I now understand why people were clamoring for a larger Harpy. If it'd be a G10 model (colors!), I'd get a couple myself. (The Matriarch and Civilian really aren't just larger Harpies.)
BTW, could someone tell me why there's only one liner? I understand that it keeps down the weight, but a second liner would allow for another set of clip screw holes, which would make the knife totally ambidextrous. Personally, it's not an issue for me, and the knife is more than solid. I'm just curious.
Maybe I'm not being fair about the ease of sharpening, since the part that took me the most time was the recurved plain section right at the point. That'll never be easy. But I'm beginning to think that ATS steels, in general, deserve their hard-to-sharpen reputation. If VG-10 costs about the same, I'd go with it 10 times out of 10.
Oh, here's a tip about getting a tip on this little guy... Sharpening the recurved, plain-edged front part (about 1/8 of the knife) will almost always get you a dull point, as it will on most knives. I kept trying to carefully fashion a needle-sharp point as my last step, but that was dulling the front edge. And then I realized something: you can turn your Harpy completely upside down, so that the handle points to the ceiling and the knife looks like an upside-down question mark, and then you can sharpen the tip by working the rear end of the point perpendicular to a stone. If that doesn't make sense, let me know, because it did a great job.
Overall, I really like the knife and I'm very glad I got the G10 version. It'll find its way into my pocket, primarily as a backup and a not-so-enormous work tool.
Schmackey,
Thanks for the great report on your G-10 Harpy. I have been interested in these knives for some time. I'm not sure what I'd use it for, but I will likely end up with one so that I can find out.
Jeff/1911.
I have ended up carrying the G10 Harpy in the yard/garden more than any other. The pull cut is very useful in many pruning situations.
Thanks for the sharpening tip, Shmackey. I'll give it a try.
Hi Shmackey. We used the single liner to hold the clip screws. We coulod have added a double liner and made it ambi, but it would make it thicker and heavier (not great for EDC). It the model turned out to be successful, we would have made a left hand version like we did with the original Harpy (left/right/plain/serrated). But alas, the sales would not support the model. Enjoy yours, it's a very tough knife.
sal
I carry a G-10 Harpy every day at work. If there ever IS a larger-sized Harpy (esp with G-10 scales) I feel confident that it would replace my "out of print" Harpy.
Folks,
So if I'm looking for a Harpy, it sounds like the G-10 version is the way to go, assuming I can find one. I had figured upon buying a S/S version up to now.
Jeff/1911.
Well Jeff, you could always try one or the other...my G-10 is my work knife, and when away from work, I carry a stainless Harpy (with stippling added to handles for improved grip). I like the way the stainless knife looks, but G-10 is great for all-round use.
The G-10 Harpy is an incredible user. I've been carrying mine for several months and it just keeps begging for harder and harder use. Aside from plants and rope, I've found the hawkbill shape's way of dropping the point makes it an excellent knife for tip work. If you need good tip control it's way more comfortable and accurate (for me) than a straighter blade would be. The Harpy is also the best electrical knife I've used. I use the serrations for stripping wire, and the tip makes it easy to pick one wire out of a bundle without cutting them all. I've also used it to cut a bandage off my friend's arm, edge up, of course, seemed to work better than a more conventional blade shape.
I'd been dreading having to sharpen it, but it sharpened up much easier than I thought it would on my Lansky. Only problem I've had is that the edge seems to roll a bit easier than most other knives. Responds well to a steel though, just need to use a thin one.
eBay often has one or two G-10 Harpies at a time, going price seems to be around $50, and it's worth way more than that.
Only one bad thing about G-10 harpy: When you have one you want G-10 Standard too. Same handle, same feeling of bombproofness.
Fine fine knives indeed! I'm really happy to have both.:D
Great - two lines and two typos:rolleyes:
I don't have a G10 Harpy, but I'm more than satisfied with the SS version. It has considerable heft and looks pretty classy. I agree with Tommi, the Standard is also a great knife.
Matt
