... Or a combo of the 2.
What he said!^^^ Yes you can pack it with JB Weld etc.. if you want to keep it for a shop knife? Fine.. I wouldn’t let anything with my name on it, out in public looking like that!————————- I’ve said these before, if you haven’t had to grind/bust off a set of expensive scales & start over? You haven’t made very many knives!I think you will happiest in the end if you heat it up, pull it apart, and redo it. Otherwise, fill it with glue or epoxy, but it will still show, and bother you.
Another reason that happens is over-clamping. The clamps should just barely apply enough force to hold the scales in place while the resin is curing. Too much force and you either squeeze out all the resin, or warp the scales up at the ends.
