Gas Forges
I am considering buying a commercial made gas forge. I am leaning towards the three burner NC Whisper Low Boy. Does anyone have any experience with this model or have any suggestions on another model.
Norseman,
I have the three burner NC Whisper Low Boy and really love it. Some of the more well known smiths I can think of who own one are ABS Master Smiths David Anders and Jerry Fisk. It seems that Joe Flournoy may have told me that he has one as well. There is also one in use at the Bill Moran School of Bladesmithing in Old Washington, Arkansas. They teach bladesmithing with both coal and gas.
I would suggest that if you buy one, have them send you a couple of welding bricks also, if you are going to make Damascus. These lay in the bottom of the forge and protect it from the flux. Flux will really eat up the bottom of a forge.
Norseman,
I also have the three burner Low Boy and have really liked it. I do all my heat treating in it, including 440-c stainless steel. (yes it can be done quite successfully)
But, get them bricks if you plan on welding. I'm going to get me some now that I know about them. Flux has ate my forge for lunch!
The thing I like best about the NC forges is you don't need any electricity to run them and they still get hot enough to do whatever you need to do.
Get one, you can't go wrong for the money!
Craig Blankenship
Blankenship Knives
http://www.blankenship-knives.com
I'm all for the homemade variety of forges. I have used just about every commercial forge out there at one time or another, and unless someone has recently come up with something other than a square design.........I don't feel it's worth the trouble. Square forge chambers, no matter how well insulated, present the problem of "hot spots". Anywhere they put the burner(s) in this design will cause the flame to be in direct contact with some portion of your work piece. It will work for steels that are not temp sensitive, but when you get into different types of damascus or steels such as 52100, you are likely to have problems.
Ed Caffrey
"The Montana Bladesmith"
www.caffreyknives.com
same here Ed,
i'm working on building a huge forge, round of coarse. about 24" inner dia. without insulation.
Thanks for the input guys. I think I'll go with the NC Whisper Low Boy. I need to spend any spare time I have making knives not building forges. Someday when I have more time than money (not that I have any extra of that either) I will try building a forge, but for now I guess I will have to pay to play!
As long as it is realized and accepted that warriors must comprehend right and wrong, and strive to do right and avoid wrong, then the way of the warriors is alive.
