- May 18, 2009
Please excuse any terminology that may be incorrect.
I am trying to piece together some equipment. Right now I'm building a workbench and have gotten a stellar deal on a drill press. Next I'm thinking bandsaw and belt grinder/sander. Do you think this harbor freight grinder would suffice (for now)? Looking to do scandi and flat grinds but I imaging if I want to do convex I would need something with a slack belt on it?
http://www.harborfreight.com/4-inch-x-36-inch-belt-6-inch-disc-sander-97181.html
Adjustable 80 grit belt sands inside and outside curves
Reliable 3/4 HP motor prevents stalling
Cast aluminum work table and 6" diameter disc
Table tilts to 60° and can be repositioned for use with belt or disc
Safety switch with miter gauge
Steel motor housing
Maximum speed: 1780 RPM (disc)/1150 FPM (belt)
Amps: 1.9 (no load), 8.6 (startup)
120V, 60 Hz
Disc: 6" diameter
Belt: 36" L x 4" W
Overall dimensions: 14" L x 19-7/8" W x 12-3/4" H
Shipping Weight: 41.56 lbs.
Steel motor housing
120V, 60 Hz
Disc: 6" diameter
Belt: 36" L x 4" W
