Berickson47
- Mar 6, 2017
I’m sure it is fine.
I just took down my 73 to less than 15 degrees per side and it hasn’t had any problems.
I find GEC factory angles a bit obtuse.
Thanks for the feedback guys. I know I can’t put the steel back on, I’m asking because I’m contemplating doing this to my other GECs. But I think I’ll do 20 DPS so I don’t remove so much steel.
I also think that when I sharpened it I rounded the back half of the blade up toward the spine a bit, removing the sharpening notch. I wasn’t careful enough and I probably applied too much pressure.
- (of an angle) more than 90° and less than 180°.
Yes it does. Tip hasn’t moved at all in the handle.Does the tip still rest below the handle/liner when closed?
Personally, I don’t notice a performance difference between 20 DPS and 15 DPS. 20 degrees, in my opinion, is the perfect medium between aesthetic, function, and longevity.Why? I removed a bit of steel when I first reprofiled my #73. I've removed comparatively little since. While it may not look as aesthetically pleasing as a completely full, straight-outta-tube blade, I'd much rather have the superior cutting ability of a knife over minty freshness.
I totally agree with you, but I like to think I’ll have this knife for 50+ years. I doubt I will though.Longevity? I stopped worrying about that long ago. I'm more likely to lose a knife than wear one out. And should that ever happen, that's the perfect excuse to buy a new one.
