- Jul 11, 2021
Hi all
I recently made my first san mai knife and besides a few issues with the bevels was really happy with how it came out. It was my first attempt at forge welding and as far as I can tell it worked beautifully.
Unfortunately I was a bit rough when fitting the handle and snapped the tang off. I could have TIG welded it back on, but combined with the bevel issues I decided to break the blade itself as well and see what the weld and grain looked like.
I suspect my heat treatment process was not optimal, since I shouldn't really have been able to snap the tang off (at least, not easily) if it had been tempered properly. Additionally, the blade only bent about 15-20 degrees before snapping (though that's a guess - I should have filmed it and used a protractor to confirm).
My question for you all is whether that sounds like the blade was under-tempered (or had some other issue), or whether it's within the normal range of toughness you'd expect from a knife. Vague question, I know. I'm mostly just looking for advice to improve future knives.
The blade had a 15N20 core and 1084 cladding. The heat treatment process was:
1) Normalise by heating to 870C, cooling, 840C, cooling, 800C, cooling, something <800C, cooling
2) Heated to 815C, soaked for about a minute, then quenched in canola oil preheated to 50C
3) Waited for it to cool in the oil, then cooled to room temperature on the bench and brushed the crap off
4) Tempered twice in the oven at 200C for two hours, cooling on the bench in between
Here's a couple of pics of the unbroken blade:
And here's a couple showing the grain after breaking the blade:
Any suggestions? Next time I'll make the notches in the tang semicircular, to avoid those stress risers, and probably try a differential temper to further reduce the hardness of the spine.
I also won't bash it with a hammer to try and fit the handle
